RCU Forums - View Single Post - Need gasket material - OS 35FP
Old 07-25-2015 | 03:53 PM
1QwkSport2.5r's Avatar
1QwkSport2.5r
You would want to use as thin of paper as necessary to seal. If you use too thick of material on say a backplate, the crankcase volume may increase enough to throw the volume off enough to make the crankcase not pressurize enough for proper air/fuel transfer and make the engine run weird/poorly. In my non-technical thought process, less is more in this case I think.
