Hello guys,
A few weeks ago I purchased a Fantasita 70 from Mike at F3Aunlimited. I have been working on the plane and I have a quick question regarding the stab. From what I can tell, the carbon rods which connect the two elevator halves are meant to be glued on one side (the one with the elevator horn) and screwed on the other. I am assuming that is done just in case there is a need to take the stab apart. How do you feel about using screws to hold it together? I am tempted to glue both halves to the rods. The tube which acts as the bearing will be glued to the fuse just to keep it from working loose over time. Is this what most have done?
Teo
