Originally Posted by
kwik
Grind out the pins using a dremel on the weld-seam, put in a steel bolt instead. Just glue it in with epoxy.
If you want it out again, just heat up the unit, and it will fall out.
Best advice I've seen on this subject yet. A good grade 8 bolt won't bend so easily.
