Dave it's a stainless M3 threaded rod with a copper sleeve over it each side of the ball link, I'm pretty sure it will be fine but as an alternative I have a length of 3mm solid carbon rod which might serve better - will check the flex once the servo mount has cured.
If it proves not to be stiff enough I will upgrade to a 4mm carbon rod or tube.
marcs
