RCU Forums - View Single Post - Screaming Eagle RC
Old 07-27-2015 | 04:39 PM
skullman
Beer is GOOD!
OK...so I have 3 combat planes....Bandit, GoDevil and Bandito
The Bandit and GoDevil have foam wings, a selig airfoil and both aircraft use the same wing. They have been flying since 2002 and 2004 respectively.
Wings are 64" span, the engine mount opening is standard to fit an OS .25 FX. Both aircraft use 3 servos, usually 2 standard and one mini servo for the throttle.
Both the Bandit and GoDevil are under the 3 1/2 LB weight limit.
The Bandito was Designed for SSC back when SSC began, It also uses a 64" foam wing, uses an E203 airfoil and was designed around the LA .15 or equivalent.
All of the aircraft use HDPE for the fuselage.
I will add the specs to the web page...I'm still adding the aircraft right now
