Yes, I kept the ignition, muffler etc...
I found my problem, you were both right about air and gas, the engine was getting both. It was not getting spark.
Pulled the engine and saw that the timing sensor wire had the white wire pulled out of the connector.
Corrected the problem, hopefully that will do the trick.
Thanks for the input.
