The oem check valve looks very much like a fuel filter,,If your tank is holding pressure then you must have the check valve in place. YS engines use that tank pressure vs. muffler pressure,, that's normal
the third line is likely just for fueling and refueling
It looks like this,,,
120 plumbing
good luck
