RCU Forums - View Single Post - help with ys 1.20
Old 07-30-2015 | 10:12 AM
scale only 4 me's Avatar
scale only 4 me
My Feedback: (158)
Originally Posted by rcworld2000
Ok yes then indo have the check valve.
Ok so when I filled it the other day I just used the 3rd line and at about 3/4 full I could see tank building pressure Soni stopped.
So how do you think I should fill from now on?
From what I'm getting from instructions I should remove line a then when pressure is gone then fill thru 3rd line with line an still unplugged?
Put a "T" hose fitting between the check valve and the tank, that is where your tank will overflow, a line comes off of that and you plug it with somethiing,, most use a fuel dot, and after flight you want to purge the pressure from there also,,otherwise fuel can leak from the constant tank pressure
you can buy as a set here
http://www.hangar-9.com/Products/Def...?ProdID=HAN115
good luck
ID:	2111911   Click image for larger version
