I'd also redo the air line connections at all the air cylinders. Just cut off the tubing at the air cylinder nipple and reattach. I had one like yours before and that's what it turned out to be. A small break in the air line tubing. The air valve is a good candidate as well. Could be many things. It sounds like the vibration when the engine is running is exposing the air leak.
