RCU Forums - View Single Post - Now I know what to do with that 2nd M16 Halftrack!
Old 07-31-2015 | 11:05 AM
R|M|D Photography's Avatar
R|M|D Photography
Originally Posted by Ex_Pat_Tanker
Measure up mine - 3.5" back to back, which is exactly the same as the Asiatam Opel Blitz axles (I'm guessing the White company used a standard front axle design from the same folks who supplied GM?).
Asiatam axles available separately here: http://www.asiatam.com/index.php?cat...-3-Tonner.html
Could Ryan's SCX10 mod be made to work with these? The end caps of the diff housings are separate pieces, so in theory somebody could cast up a new part to hold a bearing and second pinion to drive a rear axle?
The Asiatam ones wouldnt work because they are split in halves the wrong way.
This would be a bit more, and they are currently out of stock, but they would definitly work. They are completely adjustable width so you can make em as narrow as you need. http://www.sdi4x4.com/index.php?id_p...duct&id_lang=1
then just use these for front and back that also are width adjustable.
Obviously not cheap, but they will last. Like many have told me about Tamiya, you get what ya pay for, and these are worth the money.
