RCU Forums - View Single Post - Shared ECU Battery for 2 turbines. Possible?
Old 08-02-2015 | 04:02 PM
Jetkopter
Nick , I can only say that in another brand of engines when we put a Y cable on the throttle channel we got feed back that was causing random an un traceable shut downs. When we put the throttles on two separate channels no more problems. If you want to save weight go with two small packs and make a start pack that you can plug in on the ground with a y harness and then remove before flight. I would keep the engines separate from one another.
