Well good news and Bad news,,
I took the Raven out and while I was re programming the ELE mixing I notice that channel 8, which I was mixing with 2 had rotary nob VR(B) assigned to it instead of how it should have been set to "Null", once I fixed that the surfaces were again matched. Obviously I had moved that nob. Looks like this situation was user error after all on that aircraft, Still can't figure out why the Cub aileron servos were off, they were just Y harnessed on cnl 1, and the p-47 flaps being off is still a mystery too since I completely changed that programming after the problem, but could have been the same issue as the Raven.
Bad news,,,
Hovering the Raven about 75' up when it starts to drift towards the pits, I try to fly out of the hover and realize I have no control,, plane goes in full throttle in the corner of the pits. Fail Safe should have killed the motor, but didn't, Luckily no one or the thing was hit. Just a destroyed DA50 and aircraft. Rx will be canned as it blew apart,
So after I thought it was me not the TX, something lets me down big time,, the TX?? still a mystery, I'll send it in for testing I guess after my new TX shows up.
