Originally Posted by
JohnMac
Hi Wayne,
Thank you for your detailed reply. My guess is that item 4 is the culprit, since I already set everything up just as you wrote. I assumed that the Rsat default is to produce morse code alarm "S", but I have not set it this way as I cannot find where to do this with the Jeti box.
John
John,
My comment about setting the Morse Code Alarm in the clone receiver isn't correct. As David mentioned, the lack of the main receiver seeing a PPM input stream is what triggers that alarm condition so the setting would need to be in the main receiver, not the clone.
Connect the R14 to your Jetibox and find the Out Pin menu. Look under Sat1 and Sat2, they should both be selected for PPM Input and there should also be a PPM Alarm Code setting for each Sat port.
