Originally Posted by
Downwind3Zero
BTW. Re: CB400. If the BEC's could be programmed to a different Voltage than the servos that would open up several possibilities for pwr management of complex aircraft. It would eliminate having to use HV servos to be able to use 7.4V for lights/ECU etc. Just a thought.
Chris
Chris... The answer to your question is YES.... Each BEC on CB400 can be adjusted between 5V to 8V... Default is 5V. And they are independent of the servo pin voltage...
Also as for your FC1 (Flight Computer) you can download the PC software here:...
http://www.xicoy.com/FlightCompView.zip. The current fw version on the release is 1.0... I will let you know as new firmware is released... Great features are being tested ...
Enjoy..
David
