RCU Forums - View Single Post - Census of Hotspots !!!
Old 08-05-2015 | 11:36 AM
  #340
robson63pilot
Originally Posted by erbroens
Hello Robson, seen the plane in the picture fly and there wasnt any stability problems. This modification makes the plane look a lot different, but it also doesnt give any better flight characteritic.. The biggest issue in doing this is as the surface area must be bigger than a single standard hotspot fin, the construction should be very rigid and also the anchor point in the fuselage should be reinforced, As the standard twin fins of the HS are not prone to fluttering and are very practical I didnt seen this mod many times since.
Cant believe that I took this picture almost 10 years ago!
Hello, Erbroens
Thank you for the information.
