RCU Forums - View Single Post - Everything Radial Engines
Old 08-06-2015 | 08:14 AM
  #3709
Radial power
Originally Posted by chorner
Probably has a bit to do with the fact that there aren't very many good matches as far as airframes available, given the size and power output of the engine. So you're restricted to mostly kit builds, and kit builds of a specific plane type. Both of which lead to reduced popularity of an engine
Another good point. I think it was said a long time ago that the Il-300 uses cylinders that are much too long when compared to the actual stroke of the pistons. I seem to recall that the explanation was about having a more scale like engine for certain applications (perhaps WWI inline engines?). The downside is that this makes the engine unnecessarily tall, making it harder to cowl than it should be.
I wish OS would make a "short cylinder" version of this engine with, say, 1 to 1.5cm shorter cylinders. Same everything else. It would be so much easier to cowl...
Andrea.
