RCU Forums - View Single Post - Tamiya help needed
Old 08-07-2015 | 04:58 AM
YHR's Avatar
YHR
Originally Posted by Tanker 10
I'm putting together a Tamiya kit and have a couple of minor concerns. When I push the right stick up, the barrel depresses and vise versa. When traversing the turret, it hangs up at the 3 and 9 o clock positions along with the 5 o clock position. I've tried placing lead weight on top of the turret to counter balance that long heavy barrel but that doesn't seem to help. Any ideas?
The elevation thing is a servo thing. You need to reverse the servo setting on your radio that controls that channel.
The Tamiya rotation set up is the one design weakness(IMO). Ensure everything is engaging properly and lightly sand the turret locating tab to remove the hard edges. Try a little graphite powder on the sliding surfaces.
I am not sure what tank you have. The bigger the turret the more likely the problem.
