Go to the tamiya site and get the manual for your tank. I suggest you first set the radio so all the trim tabs are zeroed input directions are the same. Then do the setup procedure.
Before hand make sure all of the wires are connected to the same color.
The battery wire on the SS likes to get hung up on the turret wire bundle unless you tuck the connector in.
BTW where did you get the sherman?
