RCU Forums - View Single Post - Jet Central Rhino
Old 08-07-2015 | 03:13 PM
melvin
Default Jet Central Rhino
Hi Everyone
I just recieved my Rhino back from it's 25 hour maintenance and i was going through all the setup screens making sure that everything is set right. I noticed on the "Pump Pw ignit.K page it was set at +3 in large numbers. The manual says the number should be between 000 and 255. Does anyone know what the number should be set at from the factory? Also what do these numbers mean? The manual says if the number is too low that it will probably get the fuel ignited but it will not raise the temperature enough to trigger the preheat. What happens if the number is too high? Thanks for any help you can share
Mel
