RCU Forums - View Single Post - Jet Central Rhino
Old 08-08-2015 | 12:39 AM
melvin
Thanks for the info !! I'm going to set mine at 24 also and see if it starts ok at that setting! Mine is set at +3 as of now and i have figured out that if you hit the down arrow key it will go to +2 then +1 then to 255 254 253 and so on. Mine must have been set way to high in my opinion, if yours is at 24. Is this a start up parameter only? Also my turbine is not the SP version! Do you think that would make a difference on the 24 setting? Thanks for all the help and info guys
Mel
