I recut the rib at the tip of the main spar, this one fit perfect. I also adjusted the cad files for the last of the refinements.
I then upgraded my carbon tow wetter to fix the pitfalls it had the last time i used it.
Then using some carbon Tow, i applied this along the leading edge of the wing skins and the trailing edge. I then used Hysol to glue all of the structure parts together and then to glue it to the wing skins. I then used a ac clamp to clampe the aileron area's tight against the TE spar.
I'll leave this to cure for a few hours (6) and then i can pop some wings out!
