Originally Posted by
bluescoobydoo
i am using a 7.2v receiver and servos so every thing should take the voltage so I cannot see what could go wrong or am I missing something? I did want to use a gemini but how would I be able to make use of both outputs?
You wouldn't use the PowerJack. Just two outputs from the Gemini II (which are totally independent)
The Boost for Futaba Rx's shouldn't be needed in this case
