RCU Forums - View Single Post - 120mm EDF for Skymaster A-10
Old 08-13-2015 | 01:56 AM
Extreme_RC's Avatar
Extreme_RC
Originally Posted by icicles
127mm fans will fit easily. In fact they would almost get lost inside. As Mark has suggested keep the ESC. S cool with fans.
I have the same model, twin 120mm Stumax fans. Twin Yep 180 amp ESC. S.
My all up weight is 20.6 kg. Mainly because I chose to use 12s11,000mah per fan.
She handles the weight just fine. Mind you I don't think I would want to dump it.
Chris
Didn't know SM was making 120mm fans? Might be helpful to the OP if you posted up some photos of the setup and inside showing how you did your ESC, its a VERY expensive kit and one most don't want to make mistakes on!
