RCU Forums - View Single Post - DLE 55 hard to start
Old 08-14-2015 | 12:17 AM
  #31
kemp83
[h=3]By the way the starter I have, which cannot turn this DLE55, is this one with the LIPO battery, which means 450Ncm!
Turnigy Lipoly Belt Drive Starter for 2-stroke 160 & 90 Size Gas Engines.
A high efficiency motor combined with a reduction belt system make this a smooth starting and easy to hold starter motor. Equipped with an aluminum starter cone and round rubber insert for helicopter and airplane spinner cones.
Easy-press start switch makes starting easy without requiring heavy finger pressure and a built-in finger-guard promises safe starts. The smaller diameter motor case also means it's easier to hold when starting large motors.
The Turnigy Lipoly Belt Drive starter has an adjustable carrying cage for a 4s1p 14.8v 2200mAhLipoly or similar or 2 x 2000mAh 7.2v Nimh Packs. A selection of connection options includes, pre-ttached Tamiya plugs for two 2S batteries and alligator clips for easy attachment to a 12V battery with the help of a Tamiya plug on the other end.
Size: 215 x 63 x 135mm
Weight: 1077g
Engine class: Airplane 2-stroke 160 class /Heli 2-stroke 90 class
Suitable battery;
2 x 7.2v 2s 2000mAh Nimh
4S1P 14.8V 2200mAh Lipoly
PB (Lead-acid battery) 12V DC power source
Torque;
36kg/cm (2000mAh Nimh)
45kg/cm (2200mAh Lipoly)
41kg/cm (PB Lead Acid)
*Note: Do not use more than 18V
[/h]
