RCU Forums - View Single Post - Electric Starter help
Old 04-30-2002 | 06:26 PM
BingoFlyer's Avatar
BingoFlyer
Default Electric Starter help
Tom, Welcome to R/C!
Replace the starter cone insert with a softer silicon one, your LHS should have what you will need. I make sure that the prop is not already up agaist the compression so the starter gets a head start and have no problem starting .90 sized engines with a standard starter. The softer cone doesn't slip and therefore does not cause the groove you are getting with OEM.
