Originally Posted by
Steve S. Helland
Get a Sullivan Dynatron starter and mount it up to a Miller belt reduction drive, 2 12 volt batteries connected in series (which makes 24 volts), This is currently what I do. The Sullivan Megatron starter will definitely do the job. There's a guy at my flying field who has a small starter with gear reduction that does the trick too...we call it "the little starter with a big heart".
If you use the Miller reduction drive the 3/1 reduction reduces the current required by the motor so you can use a standard Sullivan motor on 24V. You do not need that expensive Dynatron.
The OP meeds to increase the voltage to the 18V maximum permitted by his unit
