RCU Forums - View Single Post - DLE 55 hard to start
Old 08-14-2015 | 11:04 AM
  #37
Truckracer
My Feedback: (19)
Originally Posted by 77chickenhawk
Well then the DLE book is wrong I guess. Because my engine runs better set at 43° than it did at 32. All it wanted to do was kick back and pre-ignite at 32° so all of you gentlemen believe what you want but I'm sticking with 43° or 44° Like the book says and what my two-stroke master technician suggested also. But one way to prove my case correct over all the other people is do a cylinder port timing which means setting the timing based off the piston location on the cylinder port. If you do a cylinder port timing I bet you it's going to be closer to my recommendation than the other
You're telling me an engine timed with "less" advance has more kick back then one with "more" advance? That my friend is not logical! You must be measuring timing by some non-typical method to come up with those numbers and still have an engine that runs right. No DLE source that I know of has ever stated how they came up with their timing numbers when most of their later engines are usually timed normal when you receive them. Also, the DLE numbers came from a book provided by Hobbico, not DLE. Rcexl who produced the DLE ignition also suggests timing in the normal 28 - 30 range.
Oh well, I really don't care what anybody does the rest of the day .... I'm going flying.
