RCU Forums - View Single Post - DLE 55 hard to start
Old 08-14-2015 | 12:12 PM
  #38
MTK
Originally Posted by 77chickenhawk
No! Two-stroke timing should be set at 43° and if you're running high-octane fuel 44°. No exceptions we are dealing with two stroke timing not for stroke timing .Four stroke timing you would set it at 32° approximately
If you set your time at 30, 32° you're going to get preignition
Geesh, that's it, I've been doing it all wrong all this time. I have my DLE55 set at it factory setting of 28 degrees BTDC and have been turning a Mezjlik 20x12- 3 blader
It specializes in one flip starts, puts out somewhere around 35 pounds of thrust (7K rpm) and is generally a joy to play with. Quiet set up too....
