Hi truck racer, as I mentioned, the engine is new. It was run briefly by the fellow I bought it from but never at full power. I ran it once. The compression is good in both cylinders and both plugs have spark. No chance that it has ever had a prop strike. I'm going to pull the engine off the airplane so I can remove the carb and clean it next. Hopefully it's just something gummed up in there.
