Originally Posted by
CraigG
Tony,
There are advocates for both of these gyros but your "toss up" comment is probably closest to the truth. FWIW, I own both and I don't think you would be disappointed with either one. If you go with the Cortex just be aware that two servo leads provide the voltage for all servos connected to the unit. With a giant warbird, I would recommend connecting a battery directly to the gyro if you go with the Cortex.
I am running 5 powerful digital servos from the Cortex and that issue of getting current through just 2 leads does concern me a bit, as 4 of them are elevons which will all be worked at the same time so maximising the current drawn. However I can't see how you get a battery input on its own into the Cortex, could you explain please? The only spare socket is for the USB connection.
