They are both different but equally easy to setup.
The IGyro uses hard coded outputs, 2 for elevator, 2 for aileron, 1 for rudder. If that satisfies your needs then you're fine. If you have a need to move things around, then the Cortex is more flexible in that it learns what is plugged in where during the learning sequence.
