You said it was doing the same with 2 different carbs?
The top of the metering valve lever - is it flush with the surrounding surface? If it's low, or there's not enough spring tension, it would cut off the fuel flow.
You should be able to "rock" or "bump" the the prop up against the compression stroke and see movement of fuel in the fuel line.
