RCU Forums - View Single Post - Thoughts on Modeltech j-3 cub
Old 10-17-2003 | 10:15 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: Thoughts on Modeltech j-3 cub
That's a pretty small cub, what size is your trainer?
And no, Cubs are not usually recommended for training on. It can be done of course, but generally, you should look for a flat bottom wing. Cubs LOOK like the wing is flat on the bottom, but they are actually semi-symmetrical. Combine that with the bolted on wing, and the weak cabin (Due to the clear plastic windows), and you have a recipe for disaster.
Stick with learning on your trainer, but you could be thinking about a Cub for a second plane.
