Originally Posted by
ahicks
So it occurs to me after reading this, that if the assembly order of the gasket and diaphragm are reversed, that pump doesn't work worth a darn.
I had a DLE-20RA come new from the factory with the metering diaphragm and gasket installed upside down...wouldn't draw fuel when I tried to start it up, even if the tank was pressurized. Flipped the diaphragm and it started on the first spin from the starter. :P
D.
