Hi Jimmy
Not yet, but if you can plug in servo cables then this is pretty easy to do. You basically have to parallel everything up to a BARC, and then solder an additional 5 wire cable to the Tamiya TBU. This is very easy as Tamiya as conveniently left the pins exposed to allow and additional cable to be solder on quite easily.
If you are interested email me.
Cheers
