Progress.
I set my fuel tray in between F2 and F3. I use the side saddle tank system and two 16oz tanks.
The tray is removable for now and may get glued in later. There will be a bit of g force on it as the tanks hang when the plane is upright. I have used this before so not worried, but probably will glue it in.
So fare the only thing missing from my kit is the F123 center stringer. This is 1/4" balsa for the noes profile. also missing was F123 "a" and F123 "b" both 1/4" balsa.
I just ended up going to the HS and got some 1/4" balsa sheets and cut them myself. I made the center F123 out of base wood as I wanted the strength at the spine.
I added a few extra stringers to the top.
Not sure why there is a set back notch in the firewall? My guess is they want you to use a thinner balsa sheet to round over on the top. Guess I will have to read the instructions
FS3 is glued in and ready for the inner cooler door layups.
I will make the doors before I glue in FS2 and FS 4
TB
