Yes, you are so right!
I make my wing saddles using high quality white silicone sealant. I run a nice even bead on the saddle on the fuse side, tape wax paper onto the wing where it meets the fuse making sure the wax paper lays down smoothly with no wrinkles.... then mount the wing on the fuse... snug it down easy... and then let the silicone cure for 24 hours. When you remove the wing and wax paper you are left with a perfectly molded wing saddle... it really works well. I have been doing it this way for years.
