Got a start on the inner cooler doors.
The doors are going to be maid from three pieces.
One is the door itself.
It has a piece of 1/32" birch ply glued to the underside. This gives it a lot of rigidity.
The second piece is the inside bottom that houses the door and will have the track on it. this gets attached to the inside of the fuselage.
The third piece is the skin that is just in front of the door as this area needs to be thin and strong. This skin will get glued in and flush out with the fuselage skin.
The opening is cut out and the two base wood stringers help keep it all together as I cut out the center crutch.
This is what the inside bottom piece will look like but with sides. This gets mounted to F7
The skin is in front to the door just behind F6.
This is kind of what the door looks like closed. but it is not finished, just a dry fit.
I will work on the sled and the rest later this week.
TB
