Originally Posted by
bandicootf16
Hi Isaac
Nice work on the cooling ducting for the C54 and esc. Will you be using the Peter Haase light weight heat sink. Is this your first contra. Will you be starting with the recommend 22x20 rear and 22x18 props.
David
Hi David
Yes, I will use the Peter Haase light weight heat sink.
This is my first contra and I will be starting with the recommend 22x20 rear and 22x18 props.
Best regards,
Isaac Najary
