Originally Posted by
bandicootf16
Hi Isaac
A few more questions if you don't mind. In post 36 you show a link between the two undercarriage legs, aluminium I guess. What is it's purpose. Does it make the undercarriage behave more like a single piece gear set resisting potential folding back of the gear. Would a carbon link be better.
What wheel axles are you using as shown in post 37.
David
Hi David,
Most of the time, especially in a hard landing one undercarriage leg tach the ground before the other one, The link between the two undercarriage legs, made of aluminum, disperses the forces to the all area of the undercarriage mount.
I think that aluminum will transfer the forces better then carbon because the bolt undercarriage will squeeze the carbon.
I use these wheel axles:
http://www.probuild-uk.co.uk/landing...er-wheels.html
Best regards,
Isaac Najary
