RCU Forums - View Single Post - Can I use A123s with this G-62 ignition?
Old 08-30-2015, 06:52 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Originally Posted by CK1
It looks like Ralph Cunninghams ignition and last I knew he did not recommend using over 6.0 volts . A freshly charged a123 will have over 7.2 volts and a nominal voltage of 6.6 . A Nimh 6.0 pack will peak slightly higher when freshly charged but the nominal voltage will be a lower 6.0 v. I would recommend using a dropping resistor or a 5.0v voltage regulator if using more than a 4.8 pack .
+1 CK1 nailed it.
