Originally Posted by
vatechguy3
Does that mount glue directly to the back of the nose ring?
Do the bolts from the motor install from the front then and are countersunk?
Tony
Hi Tony....about 1/4" back from the nose ring.
The 4mm bolts install from the front, no countersink required but I do put a single washer under the head of each bolt.
I got the bolts at Home Depot.
There are no clearance problems and I cut air intakes in each cheek....plenty of room.
I'll post a picture later tonight.
I don't know why these pictures are sideways but here they are anyway.
