Originally Posted by
mikedenilin
600 ft grass runway is marginal. Leave smoke tank empty. Go full throttle and release the brake. You should get it up put if the grass is long and grounds soft you might have problems to rotate.
Ok thank you I will try that if it looks slow i will abort.
