RCU Forums - View Single Post - Tutorial on DIY sound system
Old 09-01-2015 | 10:19 AM
YHR's Avatar
YHR
Originally Posted by Tanker 10
Thanks for the video Dan, just a couple of questions. Why the smoke button to start the tank when the transmitter has a start button, and can you still run a smoker, and how is it activated?
The start button on the transmitter is a digital code within the Heng Long MFU. The 123 Electronics sound boards need analog negative pulses to trigger sounds, and that is why the start is connected to the smoker output. The smoker can still be used.if you want to, and the fact I am using the smoker to signal the engine start makes sense. Ie when you start the engine the smoker will turn on.
