Originally Posted by
MAVROS
Hi Drac,
No problems with the pump just the leak from the injector which I replaced
HOWEVER that did not fix the fuel issue .....I now notice that a lot of fuel is ejected from the carby which I think the timing is out ....I have replaced the bearings and maybe I put timing out during assembly.
The interesting thing is the engine starts and runs ok but spits half the fuel out the carby
regards
Put the piston at TDC on compression. Take the cam cover off and the dot on the cam should be at the bottom. I've actually found checking it this way, the dot is slightly to the left.
