RCU Forums - View Single Post - Why I'm going back to glow
Old 09-04-2015 | 10:54 PM
  #92
Bambook7
JPmacG -
Thanks about the prices of castor and synthetic oil, I thought it was the other way around..
So using castor oil & synthetic oil in the blend let you enjoy benefits of both types, the question is the the proportions of those two in the mix.
I use mainly abc engines (Rossi, mvvs, sc) and for them I use Morgan Omega fuel 5%, which contains 17% oil, from which 30% castor and 70% synthetic.
That gives you 5.1% castor & 11.9% synthetic (out of total).
I add the amount of castor oil (of the quality Klotz Bennol) that gives me 6% of castor in the blend, and all my engines are happy with that for years now.
BUT, after reading this thread, my conclusion is that, first: maybe I use too much oil in my blend, and second: I should swap the proportions of castor & synthetic in my blend, meaning:
Maybe the blend should contain something like: 5% nitro. castor: between 8-10%, synthetic: 6-4% (14% lube on total), 81% methanol.
The thing is: is 4 to 6% of synthetic is enough to prevent the gumming phenomena in the engine?
Or maybe I should say: what's the minimum percentage of synthetic out of the total lube to prevent the gumming phenomena in the engine?
If one knows the answer to this, then no matter the amount of lube one uses in the blend (as long as it's above the engine minimum,off course ) - one just have to keep the right proportion inside lube blend..
So, did someone make some research\experiments about this proportion and have some insights regarding it?
Thanks!
