Finally, this is the engine bay. I put a small component platform on top of the inlets for the fuel valve shutoff, ECU, air fill up fittings, on/off switch and data logger. The turbine is mounted as far forward as you can get it for cg purposes and to get better spacing with the tailpipe. I found the supplied bypass too large to fit the available space without major re-work elected not to use it.
