It's a Kyosho Corvette ZR1 with an OS.12 engine made in the 90's.
You will need a transmitter/controller and a receiver and a battery cradle for 4-AA batteries . The battery cradle will need a plug that mates up to the switch connector.
You will need a glow starter wand and some fuel.
If the engine is good that is all you should need to get the engine running. If the gears and drivetrain , servos are good then it should drive too..
Get a transmitter,receiver and battery box and hook it up and make sure the servos work properly. Then fuel it up , heat-up the glow plug and press the prime button on the tank to prime the carb, then try and start it.
Good luck !
