RCU Forums - View Single Post - 14SG Differential Thrust Setup
Old 09-08-2015 | 07:48 AM
RickVB's Avatar
RickVB
My Feedback: (24)
I don't think you understand - I would like to adjust the throttle by 1-25% of the current throttle setting based on the rudder setting. So if the throttle is at 50%, and the rudder is set to 100% right, I want the left wing (throttle channel) set to 62.5%, and the right wing (Aux1) set to 37.5% (since 12.5 is 25% of 50). With the setup I have in my previous post, I get 75% and 25% respectively. If I set up points, all I can do is reduce or increase the effects by the same throttle amount over all throttle settings.
