RCU Forums - View Single Post - Jeti-duplex-ds-16-2.4-ghz
Thread
09-08-2015, 11:22 PM
2154
Henke Torphammar
Did some fiddling with Flight monitor. Good app after getting the hang of it :-P Now I use Jeti all way round from Batteries to Rx to BEC. Running 13 servos, linear motor for slats, electric retracts, breaks and LED light via the SBEC I found it keeping the voltage very well. 5.87-5.92volt during the whole flight. Also the Jeti telemetri adaptor for the ECU works well. MUI30 not needed any more and it's easy to setup an alarm for low EGT or low RPM to indicate flameout.
Also the jeti Power ions are nifty as you can discharge them to 2.5volt/cell. This means when my alarm sounds at 5.8volts I still have a couple of hundred mAh left to safely land.
All this in a 48" foamy
11:25 PM
Reply
Like
Henke Torphammar
View Public Profile
Send a private message to Henke Torphammar
Visit Henke Torphammar's homepage!
Find More Posts by Henke Torphammar
View iTrader Profile
